Modify a Manual Validation Flag Value
Use this API to change the value of the Program's manual validation (Force Validation Status to Development) flag.
Name
CDR_PUB_DF_PROGRAM. ModifyProgramDetails
Signature
PROCEDURE MODIFYPROGRAMDETAILS(
  P_API_VERSION  IN    NUMBER,
  P_INIT_MSG_LIST  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_COMMIT  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_VALIDATION_LEVEL  IN    NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL,
  X_RETURN_STATUS  OUT    VARCHAR2,
  X_MSG_COUNT  OUT    NUMBER,
  X_MSG_DATA  OUT    VARCHAR2,
  PIO_CDRNAMING  IN OUT    CDR_NAMING_VERSION_OBJ_TYPE,
  PI_PROGRAMOBJTYPE  IN OUT    CDR_PROGRAM_OBJ_TYPE
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
  • PIO_CDRNAMING (Mandatory) This is a parameter of table type CDR_NAMING_VERSION_OBJ_TYPE. Enter values to identify the Program definition whose flag value you want to change.
    The following attributes are required: OBJ_ID, OBJ_VER, COMPANY_ID, NS_OBJ_ID, NS_OBJ_VER.
  • PI_PROGRAMOBJTYPE (Mandatory) This is a parameter of table type CDR_PROGRAM_OBJ_TYPE that contains Program definition attributes.
    The required attributes are OBJ_ID, OBJ_VER, COMPANY_ID. Enter values to identify the Program definition whose flag value you want to change and enter the new flag value in the attribute MANUAL_VALIDATION_FLAG_RC. Enter $yesno$yes for yes, and $yesno$no for no.
