Modify a Mapping Column
Use this API to update a mapping at the Column level. You can map currently unmapped Columns, map Table Descriptor Columns to different Columns in the Table instance, change the default value for any Column, and supply or change a format string for a Column. This API enforces all Column mapping rules.
Name
CDR_PUB_DF_MAPPING.UpdateMappingColumns
Signature
PROCEDURE UPDATEMAPPINGCOLUMNS(
  P_API_VERSION  IN    NUMBER,
  P_INIT_MSG_LIST  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_COMMIT  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_VALIDATION_LEVEL  IN    NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL,
  X_RETURN_STATUS  OUT    VARCHAR2,
  X_MSG_COUNT  OUT    NUMBER,
  X_MSG_DATA  OUT    VARCHAR2,
  PI_MAPPING_COLUMNS  IN    CDR_MAPPING_COLUMNS_COLL
Parameters
This API has standard parameters (see Standard Parameters) and the following parameter:
PI_MAPPING_COLUMNS (Mandatory) This is a collection of CDR_MAPPING_COLUMNS_TYPEs. For each Column that you want to modify, initialize a CDR_MAPPING_COLUMNS_TYPE and then extend the collection. All the attributes are required.
