Modify a Notification Definition
Use this API to modify a Notification definition. You need to check out the Notification definition first.
Name
CDR_PUB_DF_NOTIFICATIONS.ModifyNotification
Signature
PROCEDURE MODIFYNOTIFICATION(
  P_API_VERSION  IN    NUMBER,
  P_INIT_MSG_LIST  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_COMMIT  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_VALIDATION_LEVEL  IN    NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL,
  X_RETURN_STATUS  OUT    VARCHAR2,
  X_MSG_COUNT  OUT    NUMBER,
  X_MSG_DATA  OUT    VARCHAR2,
  PIO_SOURCECDRNAMING  IN OUT    CDR_NAMING_VERSION_OBJ_TYPE,
  PI_CDRNOTIFICATION  IN    CDR_NOTIFICATION_OBJ_TYPE
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
  • PIO_SOURCECDRNAMING (Mandatory) This is a parameter of table type CDR_NAMING_VERSIONS_OBJ_TYPE that contains CDR Naming Version attributes.
    Initialize the attributes COMPANY_ID, OBJECT_ID, and OBJECT_VER.
  • PI_CDRNOTIFICATION (Mandatory) This is a parameter of table type CDR_NOTIFICATION_OBJ_TYPE. Provide values for the attributes you want to modify.
