Modify a Program
Use this API to modify a Program definition or instance. You can modify the name and description.
If you are modifying an instance object, you can also change the 3 REF attribute values to select a different source definition.
If you are modifying a definition, you must first check it out.
Name
CDR_PUB_DF_PROGRAM.ModifyProgramDetails
Signature
PROCEDURE MODIFYPROGRAMDETAILS(
  P_API_VERSION  IN    NUMBER,
  P_INIT_MSG_LIST  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_COMMIT  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_VALIDATION_LEVEL  IN    NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL,
  X_RETURN_STATUS  OUT    VARCHAR2,
  X_MSG_COUNT  OUT    NUMBER,
  X_MSG_DATA  OUT    VARCHAR2,
  PIO_CDRNAMING  IN OUT    CDR_NAMING_VERSION_OBJ_TYPE
Parameters
This API has standard parameters (see Standard Parameters) and the following parameter:
PIO_CDRNAMING (Mandatory) This is an IN OUT parameter of table type CDR_NAMING_VERSIONS_OBJ_TYPE that contains CDR Naming Version attributes.
