Modify Table in Clinical Data Model
Use this API to modify a table in a study or library clinical data model.
Name
DME_PUB_DF_DATA_MODEL.ModifyTableInDataModel
Signature
procedure ModifyTableInDataModel(
p_api_version 		IN NUMBER
p_init_msg_list 	IN VARCHAR2 default CDR_PUB_DEF_CONSTANTS.G_FALSE
p_commit 		IN VARCHAR2 default CDR_PUB_DEF_CONSTANTS.G_FALSE
p_validation_level 	IN NUMBER default CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL
x_return_status 	OUT NOCOPY VARCHAR2
x_msg_count 		OUT NOCOPY NUMBER
x_msg_data 		OUT NOCOPY VARCHAR2
pio_naming 		IN OUT NOCOPY cdr_naming_version_obj_type
pio_table 		IN OUT NOCOPY  cdr_dm_table_obj_type );
Parameters
This API has standard parameters (see Standard Parameters) and the following parameter:
PIO_NAMING (Mandatory): Enter current or modified values for the table as required. This is a parameter of type CDR_NAMING_VERSION_OBJ_TYPE.
