Remove a Group Role
Use this API to remove a single Role from a User Group. You can remove all Roles from the User Group at the same time by using the Remove All Group Roles API.
Name
CDR_PUB_SECURITY_PKG.RemoveGrpRoles
Signature
PROCEDURE REMOVEGRPROLES(
  P_API_VERSION  IN    NUMBER,
  P_INIT_MSG_LIST  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_COMMIT  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_VALIDATION_LEVEL  IN    NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL,
  X_RETURN_STATUS  OUT    VARCHAR2,
  X_MSG_COUNT  OUT    NUMBER,
  X_MSG_DATA  OUT    VARCHAR2,
  PIO_ROLES  IN    CDR_UG_ROLE_OBJ_TYPE
Parameters
This API has standard parameters (see Standard Parameters) and the following parameter:
PIO_ROLES (Mandatory) This parameter is of table type CDR_UG_ROLE_OBJ_TYPE that contains information about User Groups and Roles.
