Remove a Transition
Use this API to remove one or more Workflow transitions.
Name
CDR_PUB_DF_WORKFLOW.RemoveWfTransition
Signature
PROCEDURE REMOVEWFTRANSITION(
  P_API_VERSION  IN    NUMBER,
  P_INIT_MSG_LIST  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_COMMIT  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_VALIDATION_LEVEL  IN    NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL,
  X_RETURN_STATUS  OUT    VARCHAR2,
  X_MSG_COUNT  OUT    NUMBER,
  X_MSG_DATA  OUT    VARCHAR2,
  PI_CDRCHILDOBJS  IN    CDR_BASE_OBJ_COLL
Parameters
This API has standard parameters (see Standard Parameters) and the following parameter:
PI_CDRCHILDOBJS (Mandatory) This is a collection of CDR_BASE_OBJ_TYPEs.
For each Workflow transition that you want to remove, initialize a CDR_BASE_OBJ_TYPE and then extend the collection.
The following attributes are required for each Workflow transition: COMPANY_ID, OBJ_ID, OBJ_VER, NAMESPACE_OBJ_ID, NAMESPACE_OBJ_VER, OBJECT_VERSION_NUMBER.
