Reorder a Column
Use this API to reorder a Table's columns. You need to check out the Table definition whose columns you want to reorder.
Name
CDR_PUB_DF_TABLE.ReorderColumns
Signature
PROCEDURE REORDERCOLUMNS(
  P_API_VERSION  IN    NUMBER,
  P_INIT_MSG_LIST  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_COMMIT  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_VALIDATION_LEVEL  IN    NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL,
  X_RETURN_STATUS  OUT    VARCHAR2,
  X_MSG_COUNT  OUT    NUMBER,
  X_MSG_DATA  OUT    VARCHAR2,
  PI_REORDEROBJCOLL  IN    CDR_REORDER_OBJ_COLL
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
PI_REORDEROBJCOLL (Mandatory) This is a collection of CDR_REORDER_OBJ_TYPE that contains the Column objects that you want to reorder. The value for ENTRY_NUMBER must be NULL. Add the Columns to the collection in the new order in which you want them.
