Set a Customized Output Subtitle
Use this API to set a subtitle for individual RSE outputs.
Name
CDR_PUB_EXE_USER_UTILS.SetCustomOutputSubtitle
Signature
PROCEDURE SETCUSTOMOUTPUTSUBTITLE(
  P_API_VERSION  IN    NUMBER,
  P_INIT_MSG_LIST  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_COMMIT  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_VALIDATION_LEVEL  IN    NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL,
  X_RETURN_STATUS  OUT    VARCHAR2,
  X_MSG_COUNT  OUT    NUMBER,
  X_MSG_DATA  OUT    VARCHAR2,
  PI_VFILEREF  IN    CDR_PLANNED_OUTPUTS.FILEREF%TYPE,
  PI_VVALUE  IN    VARCHAR2
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
  • PI_VFILEREF (Mandatory) Enter the file reference name of the Planned Output to which you want to assign the subtitle.
  • PI_VVALUE (Mandatory) Enter the subtitle text.
