Undo Checkout Transformation Map
Use this API to undo check out the given transformation map.
Name
DME_PUB_XFORM_MAP.UndoCheckoutTransformationMap
Signature
PROCEDURE UNDOCHECKOUTTRANSFORMATIONMAP
(P_API_VERSION IN VARCHAR2,   P_INIT_MSG_LIST IN VARCHAR2 DEFAULT CDR_PUB_DEF_CONSTANTS.G_FALSE,   P_COMMIT IN VARCHAR2 DEFAULT CDR_PUB_DEF_CONSTANTS.G_FALSE,   P_VALIDATION_LEVEL IN NUMBER DEFAULT CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL,   X_RETURN_STATUS OUT NOCOPY VARCHAR2,   X_MSG_COUNT OUT NOCOPY NUMBER,   X_MSG_DATA OUT NOCOPY VARCHAR2,   PIO_NAMING IN OUT NOCOPY CDR_NAMING_VERSION_OBJ_TYPE
Parameters
This API has standard parameters (see Standard Parameters) and the following parameter:
PIO_NAMING (Mandatory). This is a parameter of table type CDR_NAMING_VERSION_OBJ_TYPE. Enter values to identify the transformation map.
The following attributes are required: COMPANY_ID, OBJ_ID, OBJ_VER, NAMESPACE_OBJ_ID, NAMESPACE_OBJ_VER, OBJECT_VERSION_NUMBER.
