32 Validation Checks
This is a public interface for all operations related to Validation Checks Batch(es), including creation, deletion, modification, and checking in and out of these objects. It also includes information on how to create or modify expressions.
This section includes the Validation Checks APIs from the following package: DME_PUB_VALIDATION_CHECK.
See Refresh Static Packages for information about the API you must run whenever you add, change, or delete a static package to be used in validation checks.
This chapter contains the following section:
