Data Review Guide View data listings, display data flow, and create discrepancies Choose a listing type and view data Default listings Default listings Default listings shows the current data in a table. After you select a study, click Data Management in the navigation bar. Note:For details on selecting a study, see Select a study from the Home page. Select Listings from the drop-down menu. Expand Default Listings in the left panel. Then, expand a clinical data model from the list. Select a listing to open it. To locate a listing, enter part of a listing name in the Search field and click the Search icon. Parent topic: Choose a listing type and view data
