Edit a Discrepancy
  1. After you select a study, click Shows a table with a magnifying glass Data Management in the navigation bar.
    For details on selecting a study, see Select a study from the Home page or Select a study from Study Manager.
  2. Select Discrepancies from the drop-down menu.
    You can also navigate to the Discrepancies interface from clicking on a data set on the Discrepancy Dashboard. For more information, see Using the Discrepancy Dashboard.
  3. Find the discrepancies you need to locate using the filters on the left panel or the top of the page. (See Find discrepancies for details on using the filters.)
  4. Select a discrepancy.
  5. In the right panel, click Shows pencil iconEdit.
    Tip:
    You can skip the remaining steps and use keyboard shortcuts to edit one discrepancy at a time by pressing Ctrl+Alt+E. Edit the Discrepancy field (if available). Press Tab to navigate to the Category field (if necessary), use the down arrow key to open the drop-down menu and select an option. Press Tab to navigate to Submit and press Enter.
  6. Edit the Discrepancy orCategory fields or select an Action. When you select an Action, you can also choose an associated Reason for the action and add a Comment. You can also select or clear the Allow Auto Close option.
  7. Click Submit.
