How can I resend data that needs coding to TMS?
If you make structural changes like updating a dictionary or adding columns to hold derived data from TMS, you can send all data that has been designated as needing coding by running the Force Rederivation job.
- Open the
Home page. - Select a study.
- Click the
Modify Study icon in the Studies panel. - Click the TMS tab.
- Click Force Rederivation to run Rederivation once, immediately. A confirmation message opens to notify you of a long processing time. But, you can still work while the rederivation runs.
- Click OK.
Parent topic: Listings FAQs
