8.2.8 Perform the Post-Upgrade Tasks
Complete the following tasks after you upgrade the WebLogic Server:
  1. Update the setDomainEnv.sh file as described in Edit setDomainEnv.sh.
  2. Remove $DOMAIN_HOME/lib/fndext.jar.
  3. Remove $DOMAIN_HOME/lib/runtime12.jar
  4. Copy runtime12.jar from the databse server as described in Copy runtime12.jar into the Domain's lib Directory.
  5. Rebuild the fndext.jar as described in Rebuild the fndext.jar file for Oracle WebLogic Server on UNIX/LINUX.
  6. Log in to the Oracle WebLogic Server Administration Console and from the Domain Structure panel, click Deployments.
  7. Review the list of deployments. If the wsm-pm deployment state appears as Failed, click Lock & Edit from the left, select the wsm-pm deployment checkbox, and click Delete.
    If the wsm-pm deployment state appears as Active and OK, skip the remaining steps.
  8. From the Change Center panel, click Activate Changes.
  9. Click Lock & Edit and then click Install from the top of the Deployments table.
  10. From Oracle WebLogic Server Administration Console 12c Home, select wsm-pm.ear for the current location in the Install Application Assistant and click Next. For example, you may see a path similar to this: $ORACLE_HOME/oracle_common/modules/oracle.wsm.pm/wsm-pm.ear
  11. Select Install this deployment as an application and click Next.
  12. For the servers, select the AdminServer and DMWServer checkboxes and click Next.
  13. For the Security section, leave the default of DD Only: Use only roles and policies that are defined in the deployment descriptors and click Next.
  14. Click Finish.
  15. From the Change Center panel, click Activate Changes.
  16. Click Control and select the wsm-pm checkbox from the list of deployments. Then click Servicing all requests from the Start drop-down menu at the bottom of the Deployments table.
  17. Review the list of deployments. Check that the wsm-pm deployment health appears active and OK in the System Status panel.
