6.4.3 Use the tzselect Utility
Many UNIX systems provide the tzselect utility to aid in selecting a Posix standard time zone format. You enter this command at the UNIX command prompt with no arguments and it prompts you to select a continent or ocean and then a time zone region. It returns the string to use in the TZ command.
See your operating system documentation for more information about this command in your specific environment.
