8.2.10 Verfiy the Upgrade
Ensure that you completed the upgrade successfully by following these steps:
  1. Log in to the Oracle WebLogic server as a WebLogic Install user.
  2. From the Domain Structure panel, expand Environment and select Servers.
  3. Select Admin Server and click the Monitoring tab.
  4. In the WebLogic Version field, verify the version shown. You should see WebLogic Server 12.2.1.4.0.
  5. Verify the version on all Managed Servers. If you do not see the correct version, repeat the necessary procedures in this section.
