Apply a snapshot label during job submission
You can apply a label to source and/or target tables when you submit a program (transformation or validation check) or load set (data load) in Oracle LSH.
Log in to Oracle LSH.
Expand the Life Sciences Data Hub node in the main menu on the left or from the Navigator drop-down. Select Applications.
Or, if Oracle LSH is already open, go to the Applications tab.
Navigate to the tables to which you want to apply a snapshot label:
In the Application Development window, click the
Search icon next to the Select Domain field.
Select Search By: Domain Name, enter
DMW_DOMAIN
, then click Go. -
Click the
Quick Select icon for DMW_DOMAIN.
Expand the node for the study grouping domain that contains the study.
Expand the node for the study.
Click the link for the lifecycle application area. A list of work areas, one for each installed clinical data model, appears. The model name is in the work area description.
Click the link for the work area. A list of tables and other objects in the clinical data model appears. DMW transformations and validation check batches are shown as programs. DMW file loads are shown as load sets.
Click the link of the program or load set in the Name column.
Click Submit.
In Apply Snapshot Label, select Targets, Sources, or Both.
In the Label field, enter the label.
Set all other parameters and click Submit.
Parent topic: Snapshot labels
