Can I speed up my custom SAS program's runtime?
To improve performance, SAS programs can invoke SAS direct load processing if the following conditions are met:
The target table processing type for SAS program must be Staging, either With or Without Audit.
The target table descriptor must have "Target as Dataset" set to Yes.
The administrator must enter the SQL Loader file location in the Detail attribute of the SAS service location in LSH.
Parent topic: FAQ
