Copy a validation check batch
You can copy a validation check batch from another study or from a different clinical data model in the same study. Disabled validation checks, if any, are included in the copy. No source tables are copied.
Tip:
Copy validation check batches after completing the transformation that writes to the model, so that the system can handle them appropriately.
Parent topic: Create validation checks
