Run validation check batches and view run history
  1. Go to Icon shows a clipboard. Study Manager > Validation Checks tab.
  2. From the Model drop-down list, select the clinical data model.
  3. Select a validation check batch in the upper pane.
    The system displays information about its validation checks in the middle pane and information about its run history in the lower pane.
  4. To view all jobs, click the Icon shows a clock and a report. View Full Job History icon.
    To view only recent jobs again, click the Icon shows a funnel and a report. View Recent Jobs Only icon.
    To view log files, click the icon in the column for the type of job:
    • Log (Run History pane) The most recent manually submitted job.
    • Triggered Job Log (Run History pane) The most recent triggered job.
    • Install Job Log (Validation Check Batch pane) The most recent installation of the validation check batch.
    A validation check can be disabled so that it is not included in the batch execution. To find out if a check was included in the run, check the log file.
    See:
