Upload data files
To load data files:
Place them on the server in the location your administrator specified for the study, in the correct subdirectory. There is a subdirectory for each lifecycle stage or for each lifecycle stage/file type combination.
The file name must exactly match the file specification defined for the clinical data model; see Specify a file name convention for each lifecycle stage.
If you are loading data from a clinical data capture system other than InForm, see Load data and discrepancies from a non-InForm clinical data system.
Parent topic: Load data from a file
