Validation check batch installation
The installation process:
  • Creates or updates database packages for the generated programs.
  • Maps the validation check batch to the latest installed version of the source clinical data model.
  • Creates or updates and installs the target tables to store the discrepant data rows.
    Installing a validation check batch does not install the source clinical data model. You cannot install a validation check batch until the source model is installed.
