Select Oracle InForm tables and views for use in Oracle DMW
Select tables and views to be available in all studies by default. The study configurator can override these choices.
Internal InForm metadata and operational tables can be used in DMW studies as source tables in data transformations and viewed in the Default Listings page. Any tables and views used in study templates or standard transformations should be included in studies by default. For example, you may need SUBJECTVISITS metadata for structural reference.
The system stores the tables and views in two internal clinical data models:
The Metadata model contains tables used by the DMW metadata loading process to create the tables in each InForm input clinical data model.
The Operational Data model contains tables that store information collected during the course of the study that supports clinical data, including InForm queries, form state flags, comments, and subject visit information.
Parent topic: Cross-study setup
