Set up coding in TMS
Prerequisites:
TMS must be installed.
TMS must be integrated with DMW as specified in the DMW Installation Guide.
Dictionaries and TMS domains must be defined in TMS. Domains allow you to customize terminologies differently for different studies by creating domain-specific terms and classifications. Domains also determine default TMS system behavior.
Tip:
DMW displays the domain description, if there is one, for the user to select a TMS domain for use with a particular study. If there is no description, the system displays the TMS domain name.
For more details on TMS coding, see this video:
