Set up a data visualization tool
You can integrate an external data visualization tool so that users can view data graphically and interactively with the protection of Oracle DMW security and blinding access privileges.
Visualization tools access one clinical data model at a time, along with any custom listings that read from the model. If you are using custom listings, we recommend setting a profile value as detailed in Use custom listing name for the custom listing schema.
You can use:
- Third-party tools that use generic-type business areas to work with Oracle LSH and Oracle DMW. For more information about how to use these tools, please refer to Using the Generic Visualization Adapter.
- Oracle Business Intelligence Enterprise Edition (OBIEE). An adapter is included with
Oracle LSH. See the Oracle Life Sciences Data Hub Installation Guide and
System Administrator's Guide for instructions.
To use OBIEE, you must create business areas in Oracle LSH. The business areas that are created automatically for a clinical data model in Oracle DMW are "generic," not specialized for OBIEE. See the Oracle Life Sciences Data Hub Application Developer's Guide for instructions.
To allow users to see data in a particular DMW clinical data model, the study configurator must select the Business Area option for the model.
Parent topic: Cross-study setup
