Check Out a Business Area
Use this API to check out a Business Area definition either directly or through an instance of it.
Name
CDR_PUB_DF_BUSINESSAREA.CheckOutBusiArea
Signature
PROCEDURE CHECKOUTBUSIAREA(
  P_API_VERSION  IN    NUMBER,
  P_INIT_MSG_LIST  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_COMMIT  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_VALIDATION_LEVEL  IN    NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL,
  X_RETURN_STATUS  OUT    VARCHAR2,
  X_MSG_COUNT  OUT    NUMBER,
  X_MSG_DATA  OUT    VARCHAR2,
  PIO_BASEOBJECT  IN OUT    CDR_BASE_OBJ_TYPE,
  PI_COMMENT  IN    VARCHAR2,
  PI_ISINSTONLY  IN    VARCHAR2
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
  • PIO_BASEOBJECT (Mandatory) This is a parameter of table type CDR_BASE_OBJ_TYPE. Enter values to identify the Business Area that you want to do check out.
    If you are checking out the Business Area definition directly, enter values to identify the definition.
    If you are checking out a Business Area definition through an instance of it, enter values to identify the instance.
    The following attributes are required: COMPANY_ID,OBJ_ID,OBJ_VER,OBJECT_VERSION_NUMBER,NAMESPACE_OBJ_ID,NAMESPACE_OBJ_VER.
  • PI_COMMENT Enter the reason you are checking out the Business Area.
  • PI_ISINSTONLY (Mandatory) Enter $YESNO$NO.
