Check In a Codelist
Use this API to check in a codelist. Changed status can be verified through public view 'DME_PUB_CODELIST_V'.
Name
DME_PUB_CODE_LISTS.CheckinCodeList
Signature
PROCEDURE CHECKINCODELIST
  (P_API_VERSION      IN NUMBER,    P_INIT_MSG_LIST    IN VARCHAR2 DEFAULT CDR_PUB_DEF_CONSTANTS.G_FALSE,    p_commit           IN VARCHAR2 DEFAULT CDR_PUB_DEF_CONSTANTS.G_FALSE,    p_validation_level IN NUMBER DEFAULT CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL,    p_naming           IN OUT NOCOPY cdr_naming_version_obj_type,    x_return_status OUT NOCOPY VARCHAR2,    x_msg_count OUT NOCOPY     NUMBER,    x_msg_data OUT NOCOPY      VARCHAR2
Parameters
This API has standard parameters (see Standard Parameters) as well as the following parameter:
P_NAMING (Mandatory). This is a parameter of type CDR_NAMING_VERSION_OBJ_TYPE. Enter values for the codelist you are checking in.
