Check In a Notification Definition
Use this API to check in a Notification definition.
Name
CDR_PUB_DF_NOTIFICATIONS.CheckInNotifDef
Signature
PROCEDURE CHECKINNOTIFDEF(
  P_API_VERSION  IN    NUMBER,
  P_INIT_MSG_LIST  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_COMMIT  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_VALIDATION_LEVEL  IN    NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL,
  X_RETURN_STATUS  OUT    VARCHAR2,
  X_MSG_COUNT  OUT    NUMBER,
  X_MSG_DATA  OUT    VARCHAR2,
  PIO_CDRNOTIF  IN OUT    CDR_BASE_OBJ_TYPE,
  PI_COMMENT  IN    VARCHAR2
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
  • PIO_CDRNOTIF [Mandatory] This is a parameter of table type CDR_BASE_OBJ_TYPE that object attributes.
    Identify the Notification definition you want to check in. Provide the basic naming attributes: COMPANY_ID, OBJECT_ID, OBJECT_VER, NAMESPACE_OBJ_ID, NAMESPACE_OBJ_VER, OBJECT_VERSION_NUMBER. Initialize these attributes in CDR_BASE_OBJ_TYPE.
  • PI_COMMENT (Optional) Enter the reason you are checking in the Notification.
