Check In a Parameter
Use this API to explicitly check in a Parameter definition.
Name
CDR_PUB_DF_PARAMETER.CheckInParameter
Signature
PROCEDURE CHECKINPARAMETER(   P_API_VERSION  IN    NUMBER,   P_INIT_MSG_LIST  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,   P_COMMIT  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,   P_VALIDATION_LEVEL  IN    NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL,   X_RETURN_STATUS  OUT    VARCHAR2,   X_MSG_COUNT  OUT    NUMBER,   X_MSG_DATA  OUT    VARCHAR2,   PIO_CDRNAMING  IN OUT    CDR_BASE_OBJ_TYPE,   PI_COMMENT  IN    VARCHAR2 );
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
  • PIO_CDRNAMING (Mandatory) This is a parameter of table type CDR_BASE_OBJ_TYPE that contains CDR Naming attributes. Enter values to identify the Parameter you want to check out. The following attributes are required: COMPANY_ID,OBJ_ID,OBJ_VER,OBJECT_VERSION_NUMBER,NAMESPACE_OBJ_ID,NAMESPACE_OBJ_VER.
  • PI_COMMENT (Optional) Enter a checkin comment.
