Check Out Transformation Maps
Use this API to check out the given transformation map.
Name
DME_PUB_XFORM_MAP.CheckoutTransformationMap
Signature
PROCEDURE CHECKOUTTRANSFORMATIONMAP
(P_API_VERSION IN VARCHAR2,  P_INIT_MSG_LIST IN VARCHAR2 DEFAULT CDR_PUB_DEF_CONSTANTS.G_FALSE,  P_COMMIT IN VARCHAR2 DEFAULT CDR_PUB_DEF_CONSTANTS.G_FALSE,  P_VALIDATION_LEVEL IN NUMBER DEFAULT CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL,  X_RETURN_STATUS OUT NOCOPY VARCHAR2,  X_MSG_COUNT OUT NOCOPY NUMBER,  X_MSG_DATA OUT NOCOPY VARCHAR2,  PIO_NAMING IN OUT NOCOPY CDR_NAMING_VERSION_OBJ_TYPE
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
  • PIO_NAMING (Mandatory). This is a parameter of table type CDR_NAMING_VERSION_OBJ_TYPE. Enter values to identify the transformation map.
    The attributes for this API are:
    • COMPANY_ID
    • OBJ_ID
    • OBJ_VER
    • NAMESPACE_OBJ_ID
    • NAMESPACE_OBJ_VER
    • OBJECT_VERSION_NUMBER
