Check Out a Validation Check Batch
Use this API to check out a validation check batch.
Name
DME_PUB_VALIDATION_CHECK.CheckoutValidationCheckBatch
Signature
PROCEDURE checkoutValidationCheckBatch
(P_API_VERSION IN NUMBER,  P_INIT_MSG_LIST IN VARCHAR2 DEFAULT CDR_PUB_DEF_CONSTANTS.G_FALSE,  P_COMMIT IN VARCHAR2 DEFAULT CDR_PUB_DEF_CONSTANTS.G_FALSE,  P_VALIDATION_LEVEL IN NUMBER DEFAULT CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL,  X_RETURN_STATUS OUT NOCOPY VARCHAR2,  X_MSG_COUNT OUT NOCOPY NUMBER,  X_MSG_DATA OUT NOCOPY VARCHAR2,  PIO_NAMING IN OUT NOCOPY CDR_NAMING_VERSION_OBJ_TYPE,  PI_COMMENT IN VARCHAR2
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
  • PIO_NAMING (Mandatory). This is a parameter of table type CDR_NAMING_VERSION_OBJ_TYPE. Enter values to identify the Validation Checks Batch that you want to check in.
    The following attributes are required:
    • COMPANY_ID
    • OBJ_ID
    • OBJ_VER
  • PI_COMMENT (Optional). Enter the reason you are checking out the Validation Check Batch.
