Check In a Work Area
Use this API to check in a Work Area and all the object instances it contains.
Name
CDR_PUB_DF_WORKAREA.CheckInWorkArea
Signature
PROCEDURE CHECKINWORKAREA(
  P_API_VERSION  IN    NUMBER,
  P_INIT_MSG_LIST  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_COMMIT  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_VALIDATION_LEVEL  IN    NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL,
  X_RETURN_STATUS  OUT    VARCHAR2,
  X_MSG_COUNT  OUT    NUMBER,
  X_MSG_DATA  OUT    VARCHAR2,
  PIO_BASENAMING  IN OUT    CDR_BASE_OBJ_TYPE,
  PI_COMMENT  IN    VARCHAR2
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
  • PIO_BASENAMING (Mandatory) This is a parameter of table type CDR_BASE_OBJ_TYPE. Enter values to identify the Work Area that you want to check in.
    The following attributes are required: COMPANY_ID,OBJECT_ID,OBJECT_VER,NAMESPACE_OBJ_ID,NAMESPACE_OBJ_VER, OBJECT_VERSION_NUMBER.
  • PI_COMMENT (Optional) Enter the reason you are checking in the Work Area.
