Check In a Workflow Definition
Use this API to check in a Workflow definition object.
Name
CDR_PUB_DF_WORKFLOW.CheckInWorkFlowDef
Signature
PROCEDURE CHECKINWORKFLOWDEF(
  P_API_VERSION  IN    NUMBER,
  P_INIT_MSG_LIST  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_COMMIT  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_VALIDATION_LEVEL  IN    NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL,
  X_RETURN_STATUS  OUT    VARCHAR2,
  X_MSG_COUNT  OUT    NUMBER,
  X_MSG_DATA  OUT    VARCHAR2,
  PIO_CDRWORKFLOW  IN OUT    CDR_BASE_OBJ_TYPE,
  PI_COMMENT  IN    VARCHAR2
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
  • PIO_CDRWORKFLOW This parameter refers to the workflow definition to be checked in.
    Initialize in cdr_base_obj_type, the basic naming details (COMPANY_ID,OBJ_ID,OBJ_VER,NAMESPACE_OBJ_ID,NAMESPACE_OBJ_VER, OBJECT_VERSION_NUMBER) of the workflow to be checked in.
  • PI_COMMENT Comment to be associated with the check in operation
