Copy an Execution Setup
Use this API to duplicate one or more Execution Setups for an object.
Name
CDR_PUB_DF_EXECUTIONSETUP.CopyExecutionSetup
Signature
PROCEDURE COPYEXECUTIONSETUP(
  P_API_VERSION  IN    NUMBER,
  P_INIT_MSG_LIST  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_COMMIT  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_VALIDATION_LEVEL  IN    NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL,
  X_RETURN_STATUS  OUT    VARCHAR2,
  X_MSG_COUNT  OUT    NUMBER,
  X_MSG_DATA  OUT    VARCHAR2,
  PI_EXECUTIONSETUP  IN OUT    CDR_BASE_OBJ_COLL
Parameters
This API has standard parameters (see Standard Parameters) and the following parameter:
  • PI_EXECUTIONSETUP (Mandatory) This is a collection of CDR_BASE_OBJ_TYPEs. For each Execution Setup that you want to copy, initialize a CDR_BASE_OBJ_TYPE and then extend the collection.
    The following attributes are required: COMPANY_ID,OBJ_ID,OBJ_VER,OBJECT_VERSION_NUMBER,NAMESPACE_OBJ_ID,NAMESPACE_OBJ_VER.
