Create a Notification Recipient
Use this API to create Notification recipients. Notification recipients are group roles of a user group.
Name
CDR_PUB_DF_NOTIFICATIONS.CreateNotificationRecipient
Signature
PROCEDURE CREATENOTIFICATIONRECIPIENT(
  P_API_VERSION  IN    NUMBER,
  P_INIT_MSG_LIST  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_COMMIT  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_VALIDATION_LEVEL  IN    NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL,
  X_RETURN_STATUS  OUT    VARCHAR2,
  X_MSG_COUNT  OUT    NUMBER,
  X_MSG_DATA  OUT    VARCHAR2,
  PI_CDRNOTIFRECIPIENTS  IN    CDR_NTFRCP_COLL
Parameters
This API has standard parameters (see Standard Parameters) and the following parameter:
PI_CDRNOTIFRECIPIENTS This is a collection of CDR_NOTIF_RECIPIENT_OBJ_TYPE.
If the Notification is of type APPROVAL, for the attribute FALLBACK_FLAG_RC you need to enter $NOTIFRCPTTYPE$PRIMARY if the recipient is Primary or $NOTIFRCPTTYPE$BACKUP if the recipient is Backup.
If the Primary recipients do not respond to an APPROVAL type of Notification within the defined time frame, then the Notification is sent to the Backup recipients.
