Create a Temporary Blob
Use this API to create a temporary BLOB in a BLOB Table. Call this API before you upload Columns or Table Descriptors using the UPLOADOPERATORCOLUMNS API for a SAS or CPORT file, or before creating a Table for a SAS dataset.
Name
CDR_PUB_DF_TABLE.CreateTempBlob
Signature
PROCEDURE CREATETEMPBLOB(
  P_API_VERSION  IN    NUMBER,
  P_INIT_MSG_LIST  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_COMMIT  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_VALIDATION_LEVEL  IN    NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL,
  X_RETURN_STATUS  OUT    VARCHAR2,
  X_MSG_COUNT  OUT    NUMBER,
  X_MSG_DATA  OUT    VARCHAR2,
  PIO_TMPBLOBOBJ  IN OUT    CDR_TEMP_BLOBS_OBJ_TYPE
Parameters
This API has standard parameters (see Standard Parameters) and the following parameter:
PIO_TMPBLOBOBJ (Mandatory) This is parameter of table type CDR_TEMP_BLOBS_OBJ_TYPE that contains information about the BLOB.
The required attributes are: FILE_NAME, FILE_BLOB
