Create a Validation Supporting Document
Use this API to create a validation supporting document.
Name
CDR_PUB_VL_VALIDATION.CreateValDocument
Signature
PROCEDURE CREATEVALDOCUMENT(
P_API_VERSION IN NUMBER
,P_INIT_MSG_LIST IN VARCHAR2 DEFAULT CDR_PUB_DEF_CONSTANTS.G_FALSE
,P_COMMIT IN VARCHAR2 DEFAULT CDR_PUB_DEF_CONSTANTS.G_FALSE
,P_VALIDATION_LEVEL IN NUMBER DEFAULT CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL
,X_RETURN_STATUS OUT NOCOPY VARCHAR2
,X_MSG_COUNT OUT NOCOPY NUMBER
,X_MSG_DATA OUT NOCOPY VARCHAR2
, PI_VALDOCOBJ IN CDR_VAL_DOC_BLOB_OBJ_TYPE
Parameters
This API has standard parameters (see Standard Parameters) and the following parameter:
PI_VALDOCOBJ (Mandatory) This is a parameter of type CDR_VAL_DOC_BLOB_OBJ_TYPE.
The following attributes are required: COMPANY_ID, OBJ_ID, OBJ_VER, DOCUMENT_NAME, DESCRIPTION, FILE_NAME, OS_FILE_PATH, FILE_BLOB, FILE_CONTENT_TYPE.
