DME_PUB_VC_BATCHES_V
Use this view to see validation check batch definitional details. The following query returns the validation check batches that read from a given clinical data model:
Select * from DME_PUB_VC_BATCHES_V
where SRC_MODEL_COMPANY_ID = <company_id> and
SRC_MODEL_OBJ_ID =<obj> and
SRC_MODEL_OBJ_VER = <ver>;
The following parameters are required for operations related to a batch; for example, update, check in, uncheck, check out, install, and so on.
BATCH_MAP_COMPANY_ID
BATCH_MAP_OBJ_ID
BATCH_MAP_OBJ_VER
BATCH_MAP_NS_OBJ_ID
BATCH_MAP_NS_OBJ_VER
BATCH_MAP_OBJECT_VER_NUM
