Get a Source Code CLOB
Use this API to get the source code CLOB.
Name
CDR_PUB_DF_SOURCECODE.GetSourceCode
Signature
FUNCTION GETSOURCECODE( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, COMPANYID IN CDR_NAMINGS.COMPANY_ID%TYPE, OBJID IN CDR_NAMINGS.OBJ_ID%TYPE, OBJVER IN CDR_NAMING_VERSIONS.OBJ_VER%TYPE, NSOBJID IN CDR_NAMINGS.OBJ_ID%TYPE, NSOBJVER IN CDR_NAMING_VERSIONS.OBJ_VER%TYPE ) RETURN CLOB;
Return
Type CLOB
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
- COMPANYID (Mandatory) Enter your company ID.
 - OBJID (Mandatory) Enter the object ID of the Source Code definition.
 - OBJVER (Mandatory) Enter the object version (OBJ_VER) of the Source Code definition.
 - NSOBJID (Mandatory) Enter the object ID of the Program definition that contains the Source Code definition.
 - NSOBJVER (Mandatory) Enter the object version (OBJ_VER) of the Program definition that contains the Source Code definition.
Parent topic: Create and Modify Source Code
