Get the Usage Intent RC of a Work Area
Use this API to retrieve the current value of the Usage Intent attribute for a particular Work Area.
Name
CDR_PUB_DF_WORKAREA.GetUsageIntentRC
Signature
PROCEDURE GETUSAGEINTENTRC(
  P_API_VERSION  IN    NUMBER,
  P_INIT_MSG_LIST  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_COMMIT  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_VALIDATION_LEVEL  IN    NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL,
  X_RETURN_STATUS  OUT    VARCHAR2,
  X_MSG_COUNT  OUT    NUMBER,
  X_MSG_DATA  OUT    VARCHAR2,
  PI_COMPANY_ID  IN    CDR_NAMINGS.COMPANY_ID%TYPE,
  PI_OBJ_ID  IN    CDR_NAMINGS.OBJ_ID%TYPE,
  PI_OBJ_VER  IN    CDR_NAMING_VERSIONS.OBJ_VER%TYPE,
  PO_USAGEINTENT  OUT    CDR_WORKAREAS.USAGE_INTENT_RC%TYPE
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
  • PI_COMPANY_ID (Mandatory) Enter company ID
  • PI_OBJ_ID (Mandatory) Enter the object ID of the Work Area.
  • PI_OBJ_VER (Mandatory) Enter the object version (OBJ_VER) of the Work Area.
  • PO_USAGEINTENT This output parameter returns the current value of the Work Area's Usage Intent attribute.
