Modify a Mapping at the Table Descriptor Level
Use this API to update a mapping at the Table Descriptor level in accordance with all validation rules.
Name
CDR_PUB_DF_MAPPING.ModifyMapping
Signature
PROCEDURE UPDATEMAPPINGCOLUMNS(
  P_API_VERSION  IN    NUMBER,
  P_INIT_MSG_LIST  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_COMMIT  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_VALIDATION_LEVEL  IN    NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL,
  X_RETURN_STATUS  OUT    VARCHAR2,
  X_MSG_COUNT  OUT    NUMBER,
  X_MSG_DATA  OUT    VARCHAR2,
  PI_MAPPING_COLUMNS  IN    CDR_MAPPING_COLUMNS_COLL
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
PI_MAPPING_COLUMNS (Mandatory) This is a collection of CDR_MAPPING_COLUMNS_TYPEs. For each Column that you want to modify, initialize a CDR_MAPPING_COLUMNS_TYPE and then extend the collection. All the attributes are required.
