Modify a Role
Use this API to update a Role. You can change the name, description, and Active status of a Role.
Name
CDR_PUB_SECURITY_PKG.ModifyRole
Signature
PROCEDURE MODIFYROLE(
  P_API_VERSION  IN    NUMBER,
  P_INIT_MSG_LIST  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_COMMIT  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_VALIDATION_LEVEL  IN    NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL,
  X_RETURN_STATUS  OUT    VARCHAR2,
  X_MSG_COUNT  OUT    NUMBER,
  X_MSG_DATA  OUT    VARCHAR2,
  PIO_ROLE  IN OUT    CDR_ROLE_OBJ_TYPE
Parameters
This API has standard parameters (see Standard Parameters) and the following parameter:
PIO_ROLE (Mandatory) This is a parameter of table type CDR_ROLE_OBJ_TYPE that contains attributes related to a Role.
Required Attributes are: NAME,CODE,OBJECT VERSION NUMBER (pass 1 for this).
