Modify a Subtype
Use this API to update a subtype.
Name
CDR_PUB_SECURITY_PKG.ModifySubtype
Signature
PROCEDURE MODIFYSUBTYPE(
  P_API_VERSION  IN    NUMBER,
  P_INIT_MSG_LIST  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_COMMIT  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_VALIDATION_LEVEL  IN    NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL,
  X_RETURN_STATUS  OUT    VARCHAR2,
  X_MSG_COUNT  OUT    NUMBER,
  X_MSG_DATA  OUT    VARCHAR2,
  PIO_SUBTYPE  IN OUT    CDR_SUBTYPE_OBJ_TYPE
Parameters
This API has standard parameters (see Standard Parameters) and the following parameter:
PIO_SUBTYPE (Mandatory) This is a parameter of table type CDR_SUBTYPE_OBJ_TYPE that contains information about the object subtype.
