Modify a Variable
Use this API to modify a Variable definition or instance.
To modify a Variable definition, you must first check it out.
Name
CDR_PUB_DF_VARIABLE.ModifyVariable
Signature
PROCEDURE MODIFYVARIABLE(
  P_API_VERSION  IN    NUMBER,
  P_INIT_MSG_LIST  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_COMMIT  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_VALIDATION_LEVEL  IN    NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL,
  X_RETURN_STATUS  OUT    VARCHAR2,
  X_MSG_COUNT  OUT    NUMBER,
  X_MSG_DATA  OUT    VARCHAR2,
  PI_NAMING  IN OUT    CDR_NAMING_VERSION_OBJ_TYPE,
  PI_VARIABLE  IN OUT    CDR_VAR_OBJ_TYPE
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
  • PI_NAMING (Mandatory) This is a parameter of table type CDR_NAMING_VERSIONS_OBJ_TYPE that contains CDR Naming Version attributes. Initialize the attributes COMPANY_ID, OBJECT_ID, and OBJECT_VER.
  • PI_VARIABLE (Mandatory) This is a parameter of table type CDR_VARS_OBJ_TYPE. Provide values for the attributes you want to modify.
