Refresh Static Packages
Run this API after you add, modify, or delete a static package to be used in a transformation or validation check. This is required for the changes to take effect.
Name
DME_PUB_XFORM_MAP.populateStaticPackages
Signature
PROCEDURE dme_pub_xform_map.populateStaticPackages
  ( p_api_version IN VARCHAR2
  , p_init_msg_list IN VARCHAR2 DEFAULT CDR_PUB_DEF_CONSTANTS.G_FALSE
  , p_commit IN VARCHAR2 default CDR_PUB_DEF_CONSTANTS.G_FALSE
  , p_validation_level IN NUMBER default CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL
  , x_return_status OUT NOCOPY VARCHAR2
  , x_msg_count OUT NOCOPY NUMBER
  , x_msg_data OUT NOCOPY VARCHAR2);
Parameters
This API has standard parameters (see Standard Parameters).
