Set the Primary Flag to Yes
Use this API to set the Primary Flag attribute of a specified Source Code instance to Yes. If any other Source Code instance in the parent Program is currently set to Yes, the API resets its flag to No.
Name
CDR_PUB_DF_SOURCECODE.SetPrimaryFlagRC
Signature
PROCEDURE SETPRIMARYFLAGRC(
  P_API_VERSION  IN    NUMBER,
  P_INIT_MSG_LIST  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_COMMIT  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_VALIDATION_LEVEL  IN    NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL,
  X_RETURN_STATUS  OUT    VARCHAR2,
  X_MSG_COUNT  OUT    NUMBER,
  X_MSG_DATA  OUT    VARCHAR2,
  PI_CDRSCREFBASEOBJTYPE  IN    CDR_BASE_OBJ_TYPE
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
PI_CDRSCREFBASEOBJTYPE (Mandatory) This is a parameter of table type CDR_BASE_OBJ_TYPE. Enter values to identify the Source Code instance whose PRIMARY_FLAG_RC you want to set to $YESNO$YES.
The following attributes are required: COMPANY_ID,OBJ_ID,OBJ_VER,OBJECT_VERSION_NUMBER,NAMESPACE_OBJ_ID,NAMESPACE_OBJ_VER.
