Upgrade a Validation Check Batch
Use this API to upgrade a validation check batch.
Name
DME_PUB_VALIDATION_CHECK.UpgradeValidationCheckBatch
Signature
PROCEDURE UPGRADEVALIDATIONCHECKBATCH
(P_API_VERSION IN VARCHAR2,  P_INIT_MSG_LIST IN VARCHAR2 DEFAULT CDR_PUB_DEF_CONSTANTS.G_FALSE,  P_COMMIT IN VARCHAR2 DEFAULT CDR_PUB_DEF_CONSTANTS.G_FALSE,  P_VALIDATION_LEVEL IN NUMBER DEFAULT CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL,  X_RETURN_STATUS OUT NOCOPY VARCHAR2,  X_MSG_COUNT OUT NOCOPY NUMBER,  X_MSG_DATA OUT NOCOPY VARCHAR2,  PI_BATCHMAPCOMPID IN CDR_NAMINGS.COMPANY_ID%TYPE,  PI_BATCHMAPOBJID IN CDR_NAMINGS.OBJ_ID%TYPE,  PI_BATCHMAPOBJVER IN CDR_NAMING_VERSIONS.OBJ_VER%TYPE
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
  • PI_BATCHMAPCOMPID (Mandatory). Enter COMPANY_ID of Validation Checks Batch Map.
  • PI_BATCHMAPOBJID (Mandatory). Enter OBJ_ID of Validation Checks Batch Map.
  • PI_BATCHMAPOBJVER (Mandatory). Enter OBJ_VER of Validation Checks Batch Map.
