Validate a Namespace
Use this API to validate whether a given object is created in a valid parent; for example, you may want to check if a Program Definition is a valid parent of a Table Descriptor.
Name
CDR_PUB_DEF_FACTORY_VALIDATE.ValidateNamespace
Signature
FUNCTION VALIDATENAMESPACE(
  P_API_VERSION  IN    NUMBER,
  P_INIT_MSG_LIST  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_COMMIT  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_VALIDATION_LEVEL  IN    NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL,
  PIO_SOURCECDRNAMING  IN OUT    CDR_NAMING_VERSION_OBJ_TYPE
) RETURN BOOLEAN;
Return
Type BOOLEAN
If the function returns True, then the reference is valid. Otherwise, it's invalid.
Parameters
This API has standard parameters (see Standard Parameters) and the following parameter:
PIO_SOURCECDRNAMING (Mandatory) This is a parameter of table type CDR_NAMING_VERSIONS_OBJ_TYPE that contains CDR Naming Version attributes.
For OBJECT_TYPE_RC enter the appropriate value for the object for which you want to validate a reference.
Other required attributes are: COMPANY_ID,OBJ_ID,OBJ_VER,OBJECT_TYPE_RC,NAMESPACE_OBJ_ID,NAMESPACE_OBJ_VER,REF_COMPANY_ID,REF_OBJ_ID,REF_OBJ_VER
