Oracle Life Sciences Data Hub Application Tier
In addition to standard Oracle Applications components, the Oracle LSH application tier includes the following:
Oracle LSH Application Server: The Oracle LSH Application Server renders the user interface using the Oracle Applications Framework and handles the communication between the user interface and the database using the Java Runtime Environment.
Oracle LSH Distributed Processing (DP) Server: The Oracle LSH DP Server handles the communication between Oracle LSH and the external processing systems required to support the IDEs.
Processing Systems: XML Publisher is required for internal Oracle LSH processing. The other systems are required only if you are developing Oracle LSH Programs in those technologies:
- SAS executes user-developed SAS Programs.
Parent topic: Application Tier
